piercewhat 0 #1 April 10, 2006 Camera works great on the ground and in the plane. As soon as it hits the airstream my camera throws up either ERR 01 or ERR 02. I am using the stock lens and also have tried a 24mm. I have a 4gig mem stick in there. Anyone experience this besides me? Could it be a hardware issue with the camera? Thanks in advance. Quote Share this post Link to post Share on other sites
piisfish 140 #2 April 10, 2006 http://dropzone.com/cgi-bin/forum/gforum.cgi?post=2123839;search_string=err%2001;#2123839 and http://dropzone.com/cgi-bin/forum/gforum.cgi?post=1864577;search_string=err%2002;#1864577scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
piercewhat 0 #3 April 10, 2006 Tried both of those and still not working. I tried different lenses to fix the issue but no luck. Tried different CF cards, no luck. Recharged battery over night and no luck. About to cut the camera away just to get another one. Quote Share this post Link to post Share on other sites
Fast 0 #4 April 10, 2006 What memory card are you using? I know you said you have tried other ones... But are they different types or same brand / type / size?~D Where troubles melt like lemon drops Away above the chimney tops That's where you'll find me. Swooping is taking one last poke at the bear before escaping it's cave - davelepka Quote Share this post Link to post Share on other sites
JohnRet 0 #5 April 11, 2006 How do you know that it stops working as soon as you hit the airstream? Try making a camera condom, see if that helps. Quote Share this post Link to post Share on other sites
piercewhat 0 #6 April 11, 2006 Went out and traded up for a 20D hopefully no more issues this weekend. Quote Share this post Link to post Share on other sites
sdctlc 0 #7 April 11, 2006 Are you using a MicroDrive or a CF card. There has been some talk about this previously that the Microdrives dont work above 10,000 MSL as the air pressure affects function /performance of a MD http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=1752799#1752799 Scott C."He who Hesitates Shall Inherit the Earth!" Quote Share this post Link to post Share on other sites
piercewhat 0 #8 April 11, 2006 Actually yes I am using a micro drive... I will try a CF card if this doesn't work on the next jump. Quote Share this post Link to post Share on other sites
cj1150gs 0 #9 April 11, 2006 I am sure it won't work, Please go and upgrade to a 30D. Try again with the microdrive. If it won't work, please go and upgrade to a 5D selling me the 30D real cheap Just kidding . The Microdrive does´t work up high. Carlos Martins Portugal www.cj.smugmug.com Quote Share this post Link to post Share on other sites
dragon2 2 #10 April 11, 2006 QuoteActually yes I am using a micro drive... I will try a CF card if this doesn't work on the next jump. Keep on jumping the microdrive if you want to damage it ciel bleu, Saskia Quote Share this post Link to post Share on other sites
piercewhat 0 #11 April 11, 2006 The microdrive works great for low altitude jumps from 300-800feet. Quote Share this post Link to post Share on other sites
dragon2 2 #12 April 11, 2006 QuoteThe microdrive works great for low altitude jumps from 300-800feet. It's not just altitude, it's also not exactly shock-proof. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
Fast 0 #13 April 11, 2006 QuoteAre you using a MicroDrive or a CF card. There has been some talk about this previously that the Microdrives dont work above 10,000 MSL as the air pressure affects function /performance of a MD http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=1752799#1752799 Scott C. Heh, this is what i was trying to get at. He did say he was using a CF card though. Anyways, yeah microdrives do not work for skydiving at all. Great for on the ground, crappy off the ground. At any altitude.~D Where troubles melt like lemon drops Away above the chimney tops That's where you'll find me. Swooping is taking one last poke at the bear before escaping it's cave - davelepka Quote Share this post Link to post Share on other sites
piercewhat 0 #14 April 11, 2006 Thanks for the help guys, off to the store to go get a cf card. Quote Share this post Link to post Share on other sites
