DSE 5 #1 February 22, 2007 If you're capturing via the Firewire output on the HC7, you won't care much about this post, but if you're using a Black Magic Intensity or other 10bit card, you'll find this of use. The new cams have what is called "XV Color." It's a more broad range of color, but most NLE systems can't support the range if you're capturing via Firewire. This test image shows the differences between the 8 bit and 10 bit at two shutter speeds. Quote Share this post Link to post Share on other sites
