Andybilly 0 #1 March 22, 2007 Can you post your advice for fitting the button part of a Cameye II Quote Share this post Link to post Share on other sites
BMFin 0 #2 March 22, 2007 QuoteCan you post your advice for fitting the button part of a Cameye II I drilled a small hole behind the D-box where I could take the cameye cable inside the helmet. Then I just chose a place where I drilled another hole (bigger) to exactly fit the button and even though the button fit very tightly in the hole I hot glued it to keep it there. As the cable still runs inside the helmet (under the padding ofcourse) it is easy to bring the LED in the front. Quote Share this post Link to post Share on other sites
Peej 0 #3 March 22, 2007 That's the same way i did it. Advertisio Rodriguez / Sky Quote Share this post Link to post Share on other sites
BlueSBDeath 2 #4 March 23, 2007 I did very much that same as the others, here is a picture Have fun, Stay Safe!! ArvelBSBD...........Its all about Respect, USPA#-7062, FB-2197, Outlaw 499 Quote Share this post Link to post Share on other sites
dorbie 0 #5 March 23, 2007 I trimmed the red button a bit so it was almost flush. It now takes positive pressure and is less likely to be accidentally bumped (I lost one video bumping it on exit before this). Quote Share this post Link to post Share on other sites
