CornishChris
grommet for lid
Hi.
I have just put my stills camera on my cookie lid and have had to drill a hole for the bit switch cable. I was looking at other lid set ups and saw that some people had a grommet in the hole (can't think of a better description) as per the attached pic. Where can i get one of these from. I have seen the liberal use of gaffer tape in other situations but this looks so much neater. Any ideas where I can pick one up?
Also was wondering what people do with with the bite switch when the still is not attached - do you remove the cable, let it 'hang loose', or gaffer it down?
CJP
Gods don't kill people. People with Gods kill people
Hi.
IMO you dont have enough jumps to be putting a "grommet" on your helmet... thats just asking for trouble....
--+ There are 10 types of people in the world: Those who understand binary, and those who don't.. --+
The grommets I use have a fairly small inner diameter, so when I'm not using the cable I push the cable back into the helmet and the strain-relief molding around the connector seats itself in the grommet and holds it there.
This makes installing them a bit harder, but here's what you do. Dremel/drill a hole that is just barely big enough to get the jack on the end of the cable through. Run the cable through, and use a pull-up cord to stretch the grommet over the end of the cable. Finally, push the grommet down and seat it in the surface of the helmet.
/edited to add photos
Lowes hardware - what would the equivalent be in the UK?
I would imagine that any good hardware store would have something... its just a matter of finding the right section.
but unfortunately I've never actually been to the UK and don't actually know for a fact.
Livin' on the Edge... sleeping with my rigger's wife...
