fireflytx
Problem with my Sony HC 21 - HELP
Everything looks cloudy on the screen and when it records, what the (what?) is going on? HELP! It is not zoomed ( IN?)or out.
When did it start this?? Was this from last night?? Humidity/condensation would be my guess without seeing it.
Oh, and you EDITED your post and it still doesn't make much sense.:P
Never look down on someone, unless they are going down on you.
Make sure your PROGRAM AE is set to AUTO if you are using a wide angle. Set to other will give you the cloudy look or out of focus.On the pc101 you can use them but on hc21 no go. hope this helps
TQ
I am me and you are you, so deal with it!!!
www.skydivepe.com
