andyflylife 0 #1 May 10, 2007 Hi y'all, I just thought i'd moan about my minor problem on my PC109 hopefully in order to get feedback or advice. The fault started with the LCD working without the back light and the touch screen buttons only worked part time and didnt operate the said function, but now the screen is totally black with just an interference line on it. Before it failed totally I first took off the battery to try and clear it with no affect, then i pressed the reset. After the reset I just managed to part set the time before the screen failed all together. The main problem now is that the auto focus is on after the reset and I cant change it to manual because it can only be done on the touch screen!! Sony have said £176 to fix it as a starter price Has anyone had similar problems and/or had any joy fixing them other than under warranty (ie DIY) Any thoughts appreciated.... cheers guys and gals Blues "swooper 24/7, 365!" ME on Myspace My Project playlist Quote Share this post Link to post Share on other sites
dragon2 2 #2 May 10, 2007 You could try asking Henny (Parashoot), he just prevented probably the same problem when he came across the flatcable being halfway loose while removing the handstrap on a good-as-new pc106. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
