markstone02 0 #1 May 17, 2007 Ok, So here I am looking at high defininition cameras, mounted horizontally on a flat top pro, for mainly tandems, but also with a view to doing some tv work. I want a small hi def camera that isnt going to be a chore to jump but will produce a good result for higher quality applications. A friend jumps an HDR-HC1 (Mini DV) and its been tried and tested. There are the newer HC 3 / 5 /and 7 versions above this which are scarily the same price as the lower spec hc1 (second hand as its a discontinued model). So guys. If you had the cash you would buy .... Quote Share this post Link to post Share on other sites
JohnnyZ 0 #2 May 17, 2007 I went with the HC5. I got one for $703 delivered on E-Bay. That was an unusually cheap deal, but you can get them all day long for just over $800. Quote Share this post Link to post Share on other sites
