Helmut
Xacti HD2 ????
Hmm...lessee...
Video is MPEG 4, not even AVCHD/MPEG4 pt 10, at less than 9Mbps. Macroblocking and noise are a huge issue.
http://xacticlips.cocolog-nifty.com/blog/2007/03/dmxhd2_ef28.html
has clips that you can download to see for yourself. There are also clips on the VASST website and the DVInfo.net website.
MPEG 4 isn't an easily edited format, many NLE's don't directly support it, so an HDI is required. If you've got that kind of time for editing video...go for it. Except the quality is poor, so you're spending a lot of time for a poor final master.
Then there is the form factor. It cannot be top-mounted, and the only way we could side mount it during testing, was to use industrial velcro and gaffers tape. You could modify your L-bracket to make it fit, if you're willing to have your L-bracket pointing downwards vs at a straight angle.
For about the same cost, you could end up with a Panny SD1 or for a bit more, the Sony CX7, or an HC5.
That's what I really think.:)
