dalemeyer 0 #1 February 8, 2008 Hi folks, I would like to find out what settings you are using to record in please??? Ive recently purchased the cx 7 and have not yet had the opportunity to play around with it... thanks a million daleTake it easy... and if you get it easy, take it TWICE! Quote Share this post Link to post Share on other sites
bomb420 1 #2 February 8, 2008 Some info... As the above thread suggests: manual focus, HD Quality, AVC HD 15M (XP) and the rest is fine... You can probably run on auto focus and steadshot and be completely satisfied. The camera is crispy :-DHYPOXIC Quote Share this post Link to post Share on other sites
pope 0 #3 February 9, 2008 QuoteSome info... As the above thread suggests: manual focus, HD Quality, AVC HD 15M (XP) and the rest is fine... You can probably run on auto focus and steadshot and be completely satisfied. The camera is crispy :-D I've had really shitty results using AF (with any camcorder, really) with the CX7. The camera seems to want to switch back to AF each time I power off. I wish it had a simple focus button on the outside of the camera like the early generation PC series cameras did. pope Quote Share this post Link to post Share on other sites
dalemeyer 0 #4 February 11, 2008 sweet... ill give it a go see what happens... thanksTake it easy... and if you get it easy, take it TWICE! Quote Share this post Link to post Share on other sites
mcGowan 0 #5 February 18, 2008 i have had less then favorable results using the steady shot. seems to make the video have the "i drank to much coffee jitters. i have never had very good luck with auto focus either, manual set to infinty seems to be the way to go. good luck and enjoy the camera one last thought. " the camera takes the picture, the mind and spirit create it" Quote Share this post Link to post Share on other sites
