beatcreation 0 #1 August 2, 2008 Has any one tried mounting a camcorder to their factory diver? I would love to have a full face but I also want a camera helmet. Quote Share this post Link to post Share on other sites
sdctlc 0 #2 August 2, 2008 http://www.skysystemsusa.com/helmets/sidewinder_2.html http://www.skysystemsusa.com/helmets/sidewinder_hc.html"He who Hesitates Shall Inherit the Earth!" Quote Share this post Link to post Share on other sites
beatcreation 0 #3 August 2, 2008 Im thinking more along the lines of mounting a HC3/5/7/9 to the factory diver. Quote Share this post Link to post Share on other sites
Squeak 17 #4 August 2, 2008 QuoteIm thinking more along the lines of mounting a HC3/5/7/9 to the factory diver. The sidewinder IS a Factory Diver with a Flip face and Camera boxYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
realpet 0 #5 August 4, 2008 I have Factory Diver setup with HC7. Camera mounted on top with Cookie Flatlock http://www.cookiecomposites.com/shop/Accessories/25/index.htm and Blackbox http://www.cookiecomposites.com/shop/blackbox/47/index.htm I try to remember to grab some pictures of it when I get home... - Petri Quote Share this post Link to post Share on other sites
beatcreation 0 #6 August 4, 2008 awesome, cant wait to see some pics Quote Share this post Link to post Share on other sites
sdctlc 0 #7 August 4, 2008 That is being a little picky I might say considering that you did not state any specific camera. You just initially asked if it was out there. and I provided a link for the Camera Version that Skysystems makes for the Factor Diver... The HC series is pretty wide and your likely to be looking at a top mount anyway. You can piece one together like what cookie notes with a box and a mount or even just a mount which is common. The advantage is that you can take it off and not have the extra stuff up top for jumps with out a camera. If your going to plan to do video when you have more jumps (unless your profile is not updated) and want the fullface why not look at a top mount FTN or FTP or even the Wes line through Skysystems.. A use specific helmet with room to grow as you start doing more... http://www.boneheadcomposites.com/flattop.htm http://www.boneheadcomposites.com/ftnarrow.htm http://www.skysystemsusa.com/helmets/vapor_narrow.html http://www.skysystemsusa.com/helmets/vapor_wes_pro.html Sometimes it is better to have a separate helmet anyway for what you want to do. But that is from me with 4 different helmets... Scott C."He who Hesitates Shall Inherit the Earth!" Quote Share this post Link to post Share on other sites
beatcreation 0 #8 August 5, 2008 I am thinking that I would like to get a full face but I would also like to some day use what ever new helmet I get for camera as well. I really like the idea of full face in general and I like the fit of the factory diver. I might just get one and just hope that mounting an HC series to it works ok when I try this winter or next season. Quote Share this post Link to post Share on other sites
realpet 0 #9 August 7, 2008 The pics. As can be seen from the frontview and mount_plate, the Flatlock helmet adaptor is not for this sized helment. The idea behind this is that I can finetune the camera tilt. The rectangle in the visor is the camera field of view at approx 1.2 meters (~4 feet). In the (out-of-focus) backview, the Cameye setup can be seen. When not jumping with the camera, I just pull the connector back inside the helmet. The hole is large enough to get the connector through. As the optics are not in the middle of the camera (sideways), the mount setup is a bit to the right in order to have the optics in the centre line of the helmet. - Petri Quote Share this post Link to post Share on other sites
beatcreation 0 #10 August 7, 2008 looks good petri. I like the setup. I will probably do something similar. Looks like I'm waiting till next season to get a camera but I will most definitely be picking up a factory diver soon, and now I feel comfortable that I will be able to turn it into a camera helmet if I still desire to do so. thanks all for the info. Quote Share this post Link to post Share on other sites
