missann1320 0 #1 August 5, 2008 Hey there!! Curious if anyone has any experience in mounting an external flash to the Optik Illusion? Photo attached of my current setup (I will not be flying video so what you see is the space I have to work with). I have a SC-28 cord an SB800 ready to go just need some ideas on how to safely put everything on and still allow the D200 to sit pretty. Love to know any suggestions that would work well and keep everything in place... Thanks in advance!Smile! http://www.399FirstDates.com Quote Share this post Link to post Share on other sites
diablopilot 2 #2 August 5, 2008 http://www.skysystemsusa.com/helmets/vapor_wes_pro.html---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
Foster 0 #3 August 5, 2008 might help to attach a picture of the flash to gauge the size... looking pretty limited on space though unless you put it on the side. Quote Share this post Link to post Share on other sites
parachutist 2 #4 August 5, 2008 Quote http://www.skysystemsusa.com/helmets/vapor_wes_pro.html You and I bought the Vapor at about the same time. I've put about 350 jumps on mine since. For the most part I'm very happy with this helmet, with the exception of the mouth piece hump in front. I adapted by moving the bite switch to the side of my mouth, but the adverse effect is that now I'm biting it with smaller teeth instead of wide front teeth, so the bite switch life is cut by at least 50%. Did you change anything to adapt, or are you completely comfortable with that hump as-is? Chris Quote Share this post Link to post Share on other sites
missann1320 0 #5 August 5, 2008 Quotemight help to attach a picture of the flash to gauge the size... looking pretty limited on space though unless you put it on the side. Thanks Foster good idea. Not really looking to trade out helmets at this point gentlemen- but thanks! Attached is a photo of the flash (keep in mind though it is at 90 degrees when I would have it straight out_... I think the only way is to side mount it like he said... Maybe drilling 2 spots for 2 bungees plus gaffers tape?Smile! http://www.399FirstDates.com Quote Share this post Link to post Share on other sites
PhreeZone 20 #6 August 5, 2008 An SB800 is a pretty large flash to look at mounting on anything but the side if you are putting a D200 up top. I'd look at having a bracket made to hold it on the side and then tape the shit out of the cord to keep it from coming loose. Marshall has a nice bracket for his 580EX, I'd look at that style with your set up.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
diablopilot 2 #7 August 6, 2008 I like the hump. Er, I mean I have no problem with the hump, I have moved the switch to the side slightly, I use the Conceptus tongue switch and have had no problem with my current one for more than 500 jumps..... What switch are you using? ---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
parachutist 2 #8 August 6, 2008 QuoteWhat switch are you using? Conceptus bite switch. I tried the tongue switch, but I don't seem coordinated enough to press it when I want with it off to the side. Quote Share this post Link to post Share on other sites
missann1320 0 #9 August 6, 2008 Sweet thoughts! On the 'to do' this week... Thanks much!Smile! http://www.399FirstDates.com Quote Share this post Link to post Share on other sites
