Couloirman 0 #1 October 30, 2008 anyone made their own? I refuse to pay the $300 for the bonehead model, its just not worth it to me for that much money, so Im just seeing if anyone had any ideas for a homebrewed version. I was thinking something involving a weight lifting belt and a plastic cylinder with a tripod head epoxied to the top(I have a bullet cam and a regular video camera and would use either, the bullet cam would certainly be easier to mount and not get in the way as much), but if anyone had any better ideas Im certainly open to suggestions, thanks. Quote Share this post Link to post Share on other sites
sinjin 0 #2 October 30, 2008 you can buy the parts for one at vertical visions and save some $$$. you could make it from scratch if u were motivated. i think the ball and socket piece might be the hard part to replicate. if you do, post it and good luck,, here is the vertical visians link.. http://www.vertical-visions.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=DRBK&Category_Code=BCPdont let life pass you by Quote Share this post Link to post Share on other sites
VectorBoy 0 #3 October 30, 2008 There is a similar ball clamp thing designed to hold hand held instruments in an aircraft cockpit that is available from aircraft spruce and supply. That kit of components looks to be your best bet. Quote Share this post Link to post Share on other sites
Couloirman 0 #4 October 30, 2008 Quoteyou can buy the parts for one at vertical visions and save some $$$. you could make it from scratch if u were motivated. i think the ball and socket piece might be the hard part to replicate. if you do, post it and good luck,, here is the vertical visians link.. http://www.vertical-visions.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=DRBK&Category_Code=BCP 79.99 I can handle, thanks a lot. Ill be sure to post the good results... Quote Share this post Link to post Share on other sites
diablopilot 2 #5 October 30, 2008 http://www.ram-mount.com/ Or you could buy my Bonehead mount off me.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
