davidfreefly 0 #1 April 14, 2009 hI FRIENDS, I can not edit SD videos from my Cx100 (cx105 europe) because are MPEG 4 and windows movie maker, pinnacle or sony vegas are not compatibe. Any helP? Any codec? I need a quick solution, converting from mpg4 to avi is too much time, i need something quick to edit tandem videos on the dropzone. Regads ________________________ DAVID DOVAL www.paracaidismogalicia.com Quote Share this post Link to post Share on other sites
billvon 2,991 #2 April 14, 2009 >i need something quick to edit tandem videos on the dropzone. Use composite out, get an NTSC (or PAL) to USB converter, and import as an AVI. Cheap and fast. Quote Share this post Link to post Share on other sites
davidfreefly 0 #3 April 14, 2009 Sorry could you explain better? i dont really understand ________________________ DAVID DOVAL www.paracaidismogalicia.com Quote Share this post Link to post Share on other sites
billvon 2,991 #4 April 14, 2009 >Sorry could you explain better? The camera will output regular video (i.e. via an RCA video cable.) It's either PAL or NTSC video depending on where you are. Get a video to USB adapter, play the video back on the CX100, capture it to your computer via the adapter, then edit the resulting AVI file. You will lose a lot of resolution, but it's cheap and is faster than a slow AVCHD converter. Quote Share this post Link to post Share on other sites
davidfreefly 0 #5 April 14, 2009 Ok, i understand, you mean capture video as we did with firewire and mini dv cams, but via usb. Well, is not a bad idea, but im sure it has to be more solutions. I have all videos on my labtop on mpeg 4 format. I cant belive that any video editing software can support mpeg4 Any edtition software supporting that format?? ________________________ DAVID DOVAL www.paracaidismogalicia.com Quote Share this post Link to post Share on other sites
Icon134 0 #6 April 14, 2009 QuoteI have all videos on my labtop on mpeg 4 format. I cant belive that any video editing software can support mpeg4 Any edtition software supporting that format??I'm not sure I understand what your problem is exactly... SD footage from the CX-100/105 series camera is not mpeg-4 but is mpeg-2... and sony vegas should be able to read the footage. The HD footage from the camera is AVCHD (which as I understand it is a variation of mpeg-4...) and there are several programs that can read AVCHD... Premiere Pro CS4, Sony Vegas Pro 8, Sony Vegas Movie Studio Platinum 9, and it can even be converted to be used in Final Cut Express (on an Intel Mac)...Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
dragon2 2 #7 April 14, 2009 I can edit CX105 SD and HDV files with premiere pro cs4, adobe premiere elements 7 and vegas pro 8, don't know why you can't? ciel bleu, Saskia Quote Share this post Link to post Share on other sites
davidfreefly 0 #8 April 14, 2009 oops just using older versions... time to updateThanks ________________________ DAVID DOVAL www.paracaidismogalicia.com Quote Share this post Link to post Share on other sites
DSE 5 #9 April 14, 2009 let's keep the primary CX100 thread going? Any newer NLE application can handle AVCHD, either via proxies, transcode, or native. If you're using old software, you'll need to update. Quote Share this post Link to post Share on other sites
