billbooth 10
Safety is a very relative concept. Each year, somewhere around a million jumps are made on Vectors. So while a million-to-one-shot fatal malfunction might not worry a normal jumper very much (because he will never make close to a million jumps) it worries me...because even one fatality a year due to gear failure is too many.
However, those very rare malfunctions should worry each and every one of us, because whether you die of a common, or of a very rare malfunction, you're still just as dead.
andy2 0
[/QUOTE]
well put, one of the reasons why RWS remains my favorite manufacturer of containers. Thanks bill!
let my inspiration flow,
in token rhyme suggesting rhythm...
But why do you think that other manufacturers have another point of view?
With other words: It is true: one accident caused by gear failure in one million reserve deploys is to much.
But in this rare statistics it become difficult to blame a construction principle as a possible reason for a reserve total mal.
Nowbody can say If the Vector flaps or the Mirage flaps (for example) will stay closed in a few million deploys.
So I have to say that the only way to prevent this "flap locks" in a few million deploys is to put the reserve pc on the outside of the container, not covered by any flap.
Bill, you are a ingeniously inventor and your inventions have saved countless jumpers arround the world.
But in my opinion my theory sounds as logically as yours.
x3mcam 0
As long as we are on the subject, could you give me your insight/reason to why my V3 Microns AAD pocket is under the reserve flap, and not easily used on the outside as in Mirage, Wings etc. ?
Nice rig though, even if my shoulder riser covers keep popping up. ( they're a bit tight as i use the cutaway tubes and third risers... still not nice of them opening every once in awhile..)
Tomppa
skydiverek 65
QuoteBill,
I know this one
billbooth 10
Tuck riser covers are very sensitive to the bulk under them. (Velcro riser covers didn't have this problem, by the way.) When we design a rig with tuck tabs, we can only choose one riser cover dimension, and we base that on the average bulk we expect. When your risers are "thick" like yours, you should ask your rigger to leave very little bulk at the top of your freebag. This will help your riser covers stay shut. If he can't pack with little bulk up top, perhaps your reserve is a bit too large. Even if you choose the "right size" reserve for your container, two supposedly "identical" reserves may have up to 10% different pack volumes, because of fabric and construction tolerances. Every bit of bulk, risers or canopy, up top affects your riser cover's ability to stay shut. So, if you want your riser covers to be as secure as possible, always choose a reserve that will fit "loosely" in your container, so that your riser covers can curve over your shoulders.
KellyF 16
Do you mean to say that 'pin against the back' style rigs such as the racer and reflex are at a disadvantage in this respect, and the same for rigs that position the Cypres cutter under the freebag instead of on top? The manual for my Infinity doesn't say where it should go, only says to follow procedures from Airtec, and I could not find where they specify the location either. What is the location (under/above freebag) for mine and other rigs?
Cliff, every Infinity made has been built Cypres ready, so the cutter location has been taken care of at the factory. On older style rigs (serial numbers below 6000), the cutter is located on the (jumper's) right reserve side flap, and on later models (6000 and above) it is located on the kicker flap. Both locations were tested and approved by Airtec to work properly with the container and pilot chute design in use at the time of testing.
riggerrob 644
Wow!
It is tough to decipher your "lawyerese" dialect.
On a practical note, I have only heard of one Reflex with a broken reserve closing loop and that was after it had been slammed into a King Air doorframe repeatedly by a clumbsy student.
I also heard of a similar deployment in the doorway with a Telesis (Vector I-style) student rig.
Just goes to show that students can invent new ways to mess up faster than designers can invent cures.
Tonto 1
QuoteAirtec tests every new rig design before they OK it for a Cypres. They have had several rigs with tuck-down flaps total when bench tested with a Cypres cutter. These same rigs would open fine when the ripcord was pulled, but the Cypres doesn't release the closing loop on top of the last flap like a ripcord does (on most rigs). It releases (cuts) it many layers down. The drag of the top flap coming out of the pocket, coupled with the added drag of the cut loop unlacing through several grommets while both are being "pinched" by the pilot chute spring, was enough to total the rigs. Tuck down rigs work fine most of the time, but a Cypres firing, with a bad pack job, an old, weak pilot chute spring, sand or mud in the pocket, or a too long reserve closing loop, might add up to disaster.
Wow.
Reading this thread now, written some 19 months prior to the release of the Mirage SB certainly puts several things into perspective.
I've been skydiving 20 years this week. It's so good to hear that someone who was building rigs long before I'd ever heard of a Javelin, Wings, Infinity, Icon, Vortex etc, is still well ahead of the curve. Well. At least 19 months, anyway!
Thanks so much for the information.
t
QuoteQuoteAirtec tests every new rig design before they OK it for a Cypres. They have had several rigs with tuck-down flaps total when bench tested with a Cypres cutter. These same rigs would open fine when the ripcord was pulled, but the Cypres doesn't release the closing loop on top of the last flap like a ripcord does (on most rigs). It releases (cuts) it many layers down. The drag of the top flap coming out of the pocket, coupled with the added drag of the cut loop unlacing through several grommets while both are being "pinched" by the pilot chute spring, was enough to total the rigs. Tuck down rigs work fine most of the time, but a Cypres firing, with a bad pack job, an old, weak pilot chute spring, sand or mud in the pocket, or a too long reserve closing loop, might add up to disaster.
Wow.
t
Would that be a "I told you so" or what?
Sparky
Some other manufacturers have prettier rigs than RWS (and prettier salespeople than Bill Booth too), but when it comes to safety, I think they've got everyone beat.
Dave
skydiverek 65
QuoteWow.
I thought exactly the same waw - WOW! I started this thread 19 months ago bacause I did not understand what would be a benefit of a reserve flap that does not tuck in like almost all others. I knew Bill had a reason for this "different" design. And there you have it!
skydiverek 65
QuoteI've been watching the fatality reports in Parachutist for 12 or 13 years now. Have I missed something?
Are there any documented incidents of the top flap design on a reserve container causing it to total mal in field use?
Now there might be... Thank you Bill for trying to make us as safe as possible
alan 1
QuoteIn Reply To
Now there might be... Thank you Bill for trying to make us as safe as possible !
You appear to be gloating over the possibilty that there may at some time be a documented incident of a reserve top flap design causing a total mal in field use. While I'm sure that is not what you intended, it did leave me with that impression.
Aside from that, in looking back over the thread, I stand by my question. The CYPRES cutter location seems to be the issue here not the top flap design. When bench tested, all units worked when the ripcord was pulled. Every time. It was only CYPRES activations that failed. The only time my reserve top flap will fail to open is if I fail to pull the handle or someone tampers with it.
And finally, to echo your sentiment, a big thanks to Bill Booth for his advancements in gear design and safety, as well as his willingness to share his knowledge and experience here on the boards.
Hooknswoop 19
QuoteThe CYPRES cutter location seems to be the issue here not the top flap design.
Not if the Cypres cutter location works fine if the reserve flap tucks back under itself (like the Vector III/Mircron) and doesn't tuck into the bottom flap (like the Mirage, Javelin, and Talon/VooDoo).
Derek
but I don't can agree.
On the one hand the most of the modern rigs (for example Mirage, Javelin, Wings, Infinity, Atom, Voodoo, Talon FS) have pin covers which are tucked into another flap.
They all are working great and they are all tested.
On the other hand you should agree with the argument, that all Vector styled rigs have also a less security caused by the flap covered reserve pc's.
So I think your theory is only a theory.
The theory sounds logically - but the reality is another cup of tea.
Bill, from your point of view you should built all new Vectors as pop-tops because in theory it's safer.
