PhreeZone 20
USB has a far larger market share then Firewire ever did so its going to be around longer but even it will be dead at some point. When was the last time you saw a Firewire printer or mouse?
And tomorrow is a mystery
Parachutemanuals.com
DSE 5
That's an understatement if I've ever heard one
Apple screwed Firewire (better than USB in that it owned its own bus) by keeping it proprietary and costly for too long.
PhreeZone 20
Its better to make a statement that few people can disagree with on here then one that is likely to start an arguement.
The thing to keep your eyes on moving forward is USB3 or SuperSpeed USB. 4 gig per second is the speeds its targeting. Entire memory cards would be dumped in 2-3 seconds, entire hard drives in 30-60 seconds. Cable lengths are at about 3 meters for that speed too so plenty of room to work with. First devices and chipsets should be dropping late this year or early next from the trade rags I've read. External drives are one of the first items to see this but look for it to make it to everything else shortly after it.
billvon 3,068
All of which means it's a good thing USB is getting constantly faster. It won't be long until all our video is on solid state media and we'll be transferring back and forth constantly.
DSE 5
Quote4G/S will dump a 4G card in about 12-15 seconds (counting protoocol overhead.)
This is entirely system dependent. USB bus is controlled by the CPU rather than having an independent bus. If the CPU is taxed, it'll slow down significantly. This was the sole argument in favor of 1394.
We can make USB incredibly fast, but if there is an independent governor on it that prevents max speed, it's almost pointless.
That being said, tape is dead. It's time folks realize that. Hard-store media is the present and future. Other than skydiving, our facility has been entirely tapeless for 7 years now, recording to HDD, BDPD, SXS, or CF. And for the past two years, MSPD for skydiving.
I wish that there were a means on any computer, to insert a USB card that would provide an independent bus without addressing the CPU. It would make life a lot faster.
For those reading this topic, one lesson to walk away with is ARCHIVE.
Don't go buy the cheapest HDD you can and use it for storage. Get an enterprise-grade external and keep it spun up.
Bill_K 0
What do you recommend? I'm currently looking for an eSATA enclosure and plan to put a 1tb or larger drive(s) into it. What kind of a setup do you recommend. Do you put all your raw video directly onto it and then render to another drive?
QuoteQuote
Please excuse my ignorance, could you explain what you mean by "keep it spun up"?
Thanks and Blue Skies,
Jason
PhreeZone 20
I thought that might be what he meant. I will have to check mine out and see if it has that option.
Blue skies,
Jason
DSE 5
Spendy...but my data is worth it. They only recently started shipping.
Everything's on its way out...eventually. In inventory, I've still got lots o' SCSI drives, DATs, VHS tapes, Hi-8 tapes, Phillips Cassettes, reel-to-reels, LPs, 45s, etc, etc.
