dragon2 2
QuoteQuote
Would a Tonfly box work with the HC-3 which has the D-port in the back?
Sure, it's just the lower left side that has the metal.
Without having to modify/cut the box or need tape to hold the plug in place? The Hypeye plug sticks out almost an inch from the back of the camera.
I sold my HC5, got a box left for sale, but no HC3 here to check, haven't even seen one close enough to remember where the A/V port is...
If the HC3 is shorter than the HC5 you'll have room (the box fits about flush with the back of a HC5), and tot the right of the HC5 there is a lot of room (
ciel bleu,
Saskia
HSPScott 0
I have the cookie box. I had to cut a whole to allow for the plug. I went to a boat repair shop and got some hardening agent, kind of like JB Weld and resealed where I cut the hole. I'll try and remember to take a picture of it.
SStewart 13
QuoteI sold my HC5, got a box left for sale, but no HC3 here to check, haven't even seen one close enough to remember where the A/V port is...
Here are pics, it is in the rear of the camera just below the view finder on the right.
Do you think this would fit in your Tonfly box?
Onward and Upward!
dragon2 2
If the HC3 is the same length as the HC5, this won't quite fit I think. But if you measure the HC3 from lens-mount to back, I can give you a guestimate next weekend...
ciel bleu,
Saskia
ciel bleu,
Saskia
SStewart 13
According to Sony the HC3 is 5mm longer and 4 mm shorter than the HC5, the width is the same.
I am sure that all the boxes available for tape based HD cameras were designed for the cameye with the lanc on the side. Not likely they will change the design for cameras no longer in production.
At any rate if I want to go back to a box it looks like I would have to modify it to work with the Hypeye and still have to use tape to hold the plug in place during freefall.
I have to say I like the looks of the Tonfly box the best, it would be nice to see some pics of the back of the box. The pictures on their website show a box with the HC3 from the front and the side but not the back.
Onward and Upward!
champu 1
QuoteI am sure that all the boxes available for tape based HD cameras were designed for the cameye with the lanc on the side. Not likely they will change the design for cameras no longer in production.
Ho hum... You're definitely right. Doesn't look like I'm going to have much luck...
I may be reevaluating my plans anyway. The more I think about how much this helmet (my second camera rig) is going to end up costing, the less of a big deal 4-500 bucks for a CX100 seems. And it would cut the overall width quite a bit.
