Danteb 0 #1 June 10, 2010 Hi Guys got a cam eye with a regular LANC connector but I just bought a HC52 witch has the half moon remote connector so I thot I could splice a half moon connector to the came eye but for the life of me I can't find witch wires connect to witch. would any one know how to do this or if it's even possible. I've attached pix of the half moon cable & the came eye wires tx much apreciated Quote Share this post Link to post Share on other sites
crwper 7 #2 June 10, 2010 These pages should do it for you. First, the LANC pinout: http://pinouts.ru/DigitalCameras/sony_lanc_pinout.shtml Next, the pinout for the Sony 10-pin connector (the half-moon connector): http://www.dvinfo.net/forum/attachments/sony-hvr-a1-hdr-hc-series/16718d1267336727-hdr-hc9-v-remote-terminal-lanc-sony_10pin_diagram.png You'll need to wire pins 2, 3, and 4 from the half-moon connector to pins 1, 3, and 2 of the 2.5 mm jack. Michael P.S. If this helps, I could sure use a photo of the LED end of the CamEye, as mentioned in this thread: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=3877386 Thanks! P.P.S. Looking at the 10-pin connector pinout, I just realized you may also need to pull pin 7 to ground through a 100k resistor, in order to activate the LANC interface. P.P.P.S. I also just realized your half-moon connector has only 6 wires coming from it. I'm guessing they might be breaking out only the A/V pins (i.e. everything but the 4 LANC-related pins). If this is the case, the connector you have isn't going to cut it. It might be best to purchase an adaptor cable like this one: http://www.appliedlogiceng.com/index_files/Page499.htm Quote Share this post Link to post Share on other sites
Danteb 0 #3 June 12, 2010 yup I think I cut my wires to soon, think I'll have to get one of the converter cables, only have internet at work but I'll try to take a pic of the led end Quote Share this post Link to post Share on other sites
