mchamp 1 #1 July 31, 2010 So there is a function within the CX-150 that will capture (I believe 5 or so secs) and play it back in slow-mo and was wondering if there is any particular way that Hypoxic or any other company could potentially work this into their HYPEYE D PRO function of some sort? Or even just create something that would allow the device to activate the slow motion record option? Anyone have any insight/ideas/clues on how to potentially activate/capture slow motion while in freefall?For info regarding lift ticket prices all around the world check out http://www.jumpticketprices.com/dropzones.asp Quote Share this post Link to post Share on other sites
dragon2 2 #2 July 31, 2010 Why would you use that function in freefall, why not just edit the slomo later? I've played around with that slowmo option on a HC5, IMO it's pretty useless, especially for skydiving. Also, making the hype-eye more complex isn't what most skydivers want: we'd prefer less complex! Just on/off would be good (like the cam-eye), as many of us have run into the hype-eye doing stuff we don't want it to ciel bleu, Saskia Quote Share this post Link to post Share on other sites
mchamp 1 #3 July 31, 2010 I feel as if its a more stable quality image as opposed to simply editing it and making it slow mo. Less detail would be lost I believe. The slow motion function has only a burst of 5 or so sec, but within those 5 sec more detail is recorded to the CMOS sensor therefore producing a higher quality video(not that it would matter AS much burned to a dvd, but more so on a file on a comp). Definitely got a point there regarding simplicity though IMOFor info regarding lift ticket prices all around the world check out http://www.jumpticketprices.com/dropzones.asp Quote Share this post Link to post Share on other sites
DSE 5 #4 July 31, 2010 QuoteI feel as if its a more stable quality image as opposed to simply editing it and making it slow mo. Less detail would be lost I believe. The slow motion function has only a burst of 5 or so sec, but within those 5 sec more detail is recorded to the CMOS sensor therefore producing a higher quality video(not that it would matter AS much burned to a dvd, but more so on a file on a comp). Definitely got a point there regarding simplicity though IMO Actually, you LOSE resolution, depending on the length of the slow mo. If your NLE can't do good slo mo resampling, then I'd suggest using a tool like Twixtor. You do gain very smooth motion in-camera. You lose resolution. So...if your argument is one of resolution vs smooth...resolution loses. Quote Share this post Link to post Share on other sites
PhreeZone 20 #5 July 31, 2010 Sure... unless you can get a Phantom camera to jump and then things look really nice Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
