JDL402 0 #1 November 23, 2010 Has anyone ever mounted a Hypeye D Pro inside of a Rawa vision? I have been trying to mount the switch inside the helmet where the round controller mount is right behind the top flat mounting area. The Hypeye just doesnt seem to fit, any held would be appreciated. Quote Share this post Link to post Share on other sites
chutingstar 1 #2 November 23, 2010 QuoteHas anyone ever mounted a Hypeye D Pro inside of a Rawa vision? I have been trying to mount the switch inside the helmet where the round controller mount is right behind the top flat mounting area. The Hypeye just doesnt seem to fit, any held would be appreciated. That flat area was for the CamEye II. The HypEye D Pro is mounted just below that area due to the larger base of the HypEye compared to the CamEye. Also, with the thickness of the Rawa helmet, we usually secure the HypEye D Pro with small zip-ties through two small holes on either side of each cable, near the base. I can send a photo later today. MikeChutingStar.com Quote Share this post Link to post Share on other sites
chuckakers 425 #3 November 25, 2010 QuoteQuoteHas anyone ever mounted a Hypeye D Pro inside of a Rawa vision? I have been trying to mount the switch inside the helmet where the round controller mount is right behind the top flat mounting area. The Hypeye just doesnt seem to fit, any held would be appreciated. That flat area was for the CamEye II. The HypEye D Pro is mounted just below that area due to the larger base of the HypEye compared to the CamEye. Also, with the thickness of the Rawa helmet, we usually secure the HypEye D Pro with small zip-ties through two small holes on either side of each cable, near the base. I can send a photo later today. Mike Chuting Star to the rescue. Nice job guys!Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
