sbhesq 0 #1 February 22, 2011 I imported video/audio from a Contour camera for a friend. The files are saved as .mov. When I import the files into Vegas Platinum 9 the audio seems to be getting dropped. There is sound when I play the files directly in quicktime. Any suggestions/advice on why this is happening would be greatly appreciated. Thanks, Steve Quote Share this post Link to post Share on other sites
DSE 5 #2 February 22, 2011 my first response is that you probably haven't installed DVD Architect yet. Second response is that you're perhaps using a pirate version? (MPEG is disabled due to separate authorization that is hard to find) Be sure you have Quicktime installed on your machine as well. Quicktime is the decoder used by both Sony and Adobe software. Quote Share this post Link to post Share on other sites
sbhesq 0 #3 February 22, 2011 DSE, Thanks for the reply. I am definitely not using a pirated version and I do have dvda installed. I will check to see that I have the latest version of Quicktime installed, but the vid is playing with sound on the version I currently have. I have edited many vids on here from my cx100 without any problems, but, this time I am using a friend's Contour. Thanks, Steve Quote Share this post Link to post Share on other sites
sbhesq 0 #4 February 22, 2011 I just renamed the files to .mp4 and that solved it. Quote Share this post Link to post Share on other sites
Hellis 0 #5 February 22, 2011 That works unless you have a newer version of quicktime. I dont know if the latest version of quicktime has solved the problem, but 7.6 (472) is a working version. Apple screwed up something with the codecs on the later versions. It could be solved with the latest version, but i have never tried it Quote Share this post Link to post Share on other sites
