velocityphoto
go pro default setting?
From what I've seen there is not a default setting but if you upgrade the firmware it will go back to the factory defaults.
Depending on the firmware you will see the following if the settings are set to default. Just ignore the ones that aren't in your current firmware.
onF (P2 in older)
F
r4
Cnt
UP (Not in older)
LFF (Not in older)
oSO (Not in older)
P1 (P2 in older)
bLO
bPO
nSC
Lst (Not a setting)
All (Not a setting)
OFF
LCO (Not in older)
dat (Not a setting, submenu)
ESC (Not a setting/esc)
HYPOXIC
I tried doing the firmware update and can't get it to install. Have 3 flashing zero's , can't go any further than that. Waiting on response from gopro now.
A friend will bail you out of jail , a REAL friend will be sitting next to you in the cell slapping your hand saying "DUDE THAT WAS AWSUM " ................
