shibu 1 #1 June 28, 2011 Ok. I am a newbie. Never wore a helmet cam. Has anyone ever seen a skydiver use something like this: http://www.liquidimageco.com/products/ I get how the peripheral vision would be shot with this particular pair but what about something similar. Is there anything like this for skydiving. Seems like it would be safer to haver smaller cameras that could be mounted inside of goggles or a helmet instead of having them stick out. Quote Share this post Link to post Share on other sites
DSE 5 #2 June 28, 2011 they've been discussed here several times. The compression and lens quality make them useless. for most everything but simple If your jump numbers are accurate, you might want to read the sticky... Quote Share this post Link to post Share on other sites
shibu 1 #3 July 2, 2011 Quotethey've been discussed here several times. The compression and lens quality make them useless. for most everything but simple If your jump numbers are accurate, you might want to read the sticky... I read the sticky.. The incident reports were enough to dissuade me from considering using a camera for now... I'm still researching them but I won't wear it on a dive until I have at least 200 jumps. Good looking out. Quote Share this post Link to post Share on other sites
