MrCat 0 #1 August 16, 2011 I've got a CX 115 camera that is set onto it's highest definition setting (HDFX) that is meant to be 1,920x1,080 @ 25fps. I'm just filming mainly to have a bit of fun and if they want them to give copies to the people I'm jumping with but I'm having problems grabbing still from the video. Attached are two examples. The camera is set up the same in both cases, the software used is the same in both cases and the method of grabbing is the same but the difference could not be more marked. blurred.jpg shows considerable movement / motion blur in the subjects j237exit.jpg is ok, I'd be happy to post that on facebook or similar. It's not good enough to print but it is ok. I'm using Corel VideoStudio X4 to edit / grab frames but even if I use Zoom Pro or VLC to play the vid, pause it and grab the frame from there it's no different. Any suggestions ?? and I'm not strapping a still camera to my head!! Thanks guys!!Jump more, post less. Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 August 16, 2011 Welcome to how video frames are made. Look up interlacing and you'll get a much better understanding of the issue. You will always have this issue with Interlaced cameras.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
raceface 0 #3 August 17, 2011 cd supplied with CX cameras contains PMB software which can take surprisingly good framegrabs (final image has resolution bigger than 1920x1080, i don't know how...)my pictures Quote Share this post Link to post Share on other sites
MrCat 0 #4 August 17, 2011 QuoteWelcome to how video frames are made. Look up interlacing and you'll get a much better understanding of the issue. You will always have this issue with Interlaced cameras. I had suspected that was the issue but at the same time I wasn't expecting it as I had done a quick search on cx115 interlaced and hadn't found much (in the top 20 searches) but a new search for interlaced cx115 found plenty :( Quotecd supplied with CX cameras contains PMB software which can take surprisingly good framegrabs (final image has resolution bigger than 1920x1080, i don't know how...) I had installed that on my desktop computer but not on the laptop I use for video editing. I'll give it a try - thanks :)Jump more, post less. Quote Share this post Link to post Share on other sites
MrCat 0 #5 August 17, 2011 Quotecd supplied with CX cameras contains PMB software which can take surprisingly good framegrabs (final image has resolution bigger than 1920x1080, i don't know how...) Same image via PMB - great advice - many thanks :)Jump more, post less. Quote Share this post Link to post Share on other sites
raceface 0 #6 August 17, 2011 i would like to know how PMB does it, anyone has an idea?my pictures Quote Share this post Link to post Share on other sites
bwilling 0 #7 August 30, 2011 Quotei would like to know how PMB does it, anyone has an idea? The software understands that a single frame 'grab' isn't really a 'complete' single frame due to interlacing, and 'builds' a complete single frame from the interlaced components (the frame prior to/after the actual 'grabbed' frame.) "If all you ever do is all you ever did, then all you'll ever get is all you ever got." Quote Share this post Link to post Share on other sites
raceface 0 #8 August 31, 2011 this is what i thought too, even merged from two fields, one full HD frame should have 1920x1080 pixels. but these have 2304x1296...my pictures Quote Share this post Link to post Share on other sites
MrCat 0 #9 September 8, 2011 the cool thing is... I had some old vids from my FS1 jumps that my coach had given me. Loaded them up into PMB and grabbed stills from them without any interlacing problems so the software is not just great for CX115 vids :)Jump more, post less. Quote Share this post Link to post Share on other sites
jerolim 7 #10 September 20, 2011 PMB software on my PC has Frame Capture option is disabled. Does anybody knows why ? Quote Share this post Link to post Share on other sites
