tilley13k 0 #1 October 18, 2011 Hey everyone, Does anyone have any experience with the Cookie rail mount for the ContourHD? http://www.cookiecomposites.com/shop/Accessories/93/index.htm Looks like a simple mount to easily add and remove a Contour. If anyone has any feedback regarding construction quality, durability and other pros/cons, I'd appreciate it. Thanks! Quote Share this post Link to post Share on other sites
sdsouthsask 0 #2 October 19, 2011 Very Very well made. Use it on my Gath Helmet (modified the ear vent to accept it. It holds the Contour so much better than the Contour helmet mount which is way too easy for the Contour to slide back or forward or even off. This mount is very solid and holds very tight to the Contour. Mark Quote Share this post Link to post Share on other sites
deeleyer 0 #3 October 20, 2011 Very interesting, could you post a pic? I'm still thinking about how to attach a contour to my gath. Do the camera stands next to helmet or there is some space between? Thank you. Quote Share this post Link to post Share on other sites
sdsouthsask 0 #4 October 20, 2011 Here are a few pictures. I took out the earpiece and drilled out the center post so the outer layer was removed. Then drilled two holes in the plastic part there for the screws and put on the rail mount. Then put the earpiece back on. Because of the weight of the camera on there I put a drop of krazy glue on each of the 4 pieces of the earpiece that hooks in the corresponding earpiece holder so that it cannot come off easily if it was accidentally rotated (how you take them off) Hope this makes sense. As you can see it stands out just a bit more than the contour helmet mount, but it is way more secure. Quote Share this post Link to post Share on other sites
deeleyer 0 #5 October 20, 2011 Looks great. Thanks a lot for the pics and the explanation Quote Share this post Link to post Share on other sites
tilley13k 0 #6 October 20, 2011 Awesome, thanks for the feedback! Quote Share this post Link to post Share on other sites
