mrubin 0 #1 November 15, 2011 I recently got a good deal on a Contour and am wondering if anyone has created a chest mount for it and if so, how well it works. I jump a full face helmet and am less than thrilled with the mounting options. I do a lot of RW and am a beginner wing suiter, so the camera will not be used on a wing suit jump for a while. I'm not hoping to get incredible video, just something that I can share with my friends and family who are interested and possibly use in a debrief of some coach jumps."I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery Quote Share this post Link to post Share on other sites
DSE 5 #2 November 15, 2011 I saw one last weekend, made from a small plate of plastic with a pistol rail mounted to it, and the Contour mounted to the rail. I didn't get a photo of it, but the plastic was more or less flat, two slits in it for the chest strap to go through, beneath the rail. This was on a wingsuit rig. The plastic appeared to be ABS plastic cut out with a Dremel or similar. Monkey has a lot of experience with playing with plastic, he might be able to give some suggestions. Quote Share this post Link to post Share on other sites
monkycndo 0 #3 November 16, 2011 I used to use ABS, but found that it would break if it was flexed too much. Have great video of an alti flying off after colliding during an RW jump. I am not fond of using the chest strap because as you move and change body position, the strap can loosen and the angle of the camera will change as well. I have be playing with a mudflap mount for a gopro similar to my altimount that needs some tweeking. Only have a few jumps on it so but it is very simple and rock solid. Just need some more time to jump it to get it set up. It would be pretty eas to mount some type of rail on it for the contour.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
trunk 0 #4 November 16, 2011 You can use a GoPro Chesty, drill a 1/4" hole and use a Contour Universal Mount on it. It's kinda a hack, but I've done it before. It's good for canopy flying but not so sure how good of a shot it would be for RW. -TrunkTrunk's Blog HYPOXIC's Instagram Like HYPOXIC Quote Share this post Link to post Share on other sites
mrubin 0 #5 November 16, 2011 That sounds like a pretty cool design. When you get it all set up, will you post it for the rest of us to see?"I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery Quote Share this post Link to post Share on other sites
