raceface 0
QuoteOr then you just build your own: http://www.matthoover.com/gallery/skydiving-videos/Phyxius_Project-HQ.html
couldn't resist, bought scuba hood today... :-P
my pictures
Quotefiberglass is cheap, where is the expence?
The cast:
$20 Plaster, $6 for ky unless you have a whole bunch laying around. $ 75 ~100 for the dive hood- liner.
The plug: Minimum $ 20 to $30 for various waxes ( free if you work in molding business or car detailing. $30 to $40 for 2-part expanding foam. This just gets you to the foam plug of your head stage and we are way past $100 dollars.
Yes I only spent $40 on fiberglass but $60 on enough resin to do 1 CCM ( I really spent $120 whether I build two or not) You might be able to get marine resin cheaper but not by much.
You will spend minimum $50 to well over $100 for hardware depending on if you want a cuttaway. Add in your choice of mounts, sights, electronics this thing can go well past $1000.
I didn't have to buy a single tool or any sandpaper. I didn't pay a lick of shipping, everything sourced local. My hood was free, My mounts home made from material I already had. I didn't have any re-dos or do overs and I'm up to over $400. That is not counting paint which I did myself.
The biggest hit will be your skill and perseverance during a 200 man hour project that requires much patience. That is for a bare bones unit following the instructions if you plan to deviate or customize add much more time.
I had help which is essential the instructions are good but not perfect. Advice is cheap.
The111 1
QuoteQuoteOr then you just build your own: http://www.matthoover.com/gallery/skydiving-videos/Phyxius_Project-HQ.html
If you (or anybody else) needs Wes' instructions, PM me.
www.WingsuitPhotos.com
mchamp 1
So the chincup is not as a stable plateform as the Vapor Pro's headstrap correct?
Anyone have any pics of the installed cutaway system on the Vapor Pro?
The shark just looks nice and its makes life easier to transfer my optima from a video jump to a fun jump without having to go through all the padding. Only thing I'm concerned with is that I'd like to mount a gopro on the front for backup incase the video decides to randomly shut off and it just doesn't look feasible since its curved.
I'd really like to get my hands on both of those helmets before I depart with a decent chunk of change so I could compare apples to apples, but doesn't look like I'll able to do so :( The shark is too new and not many people in the states wear TonFly's. Have seen sonic's setup looks nice though
For info regarding lift ticket prices all around the world check out
http://www.jumpticketprices.com/dropzones.asp
