cavscout73 0 #1 November 5, 2012 Does anyone on here know anything about this camera? My guess is just an updated version of the 110 specs are close to the same. From what i can see. Im just looking for some input to see if this camera is a good option. Thanks Quote Share this post Link to post Share on other sites
dragon2 2 #2 November 5, 2012 It's got OIS, so no. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
cavscout73 0 #3 November 5, 2012 The cx 110 is ois,also isnt it? Quote Share this post Link to post Share on other sites
dragon2 2 #4 November 6, 2012 click ciel bleu, Saskia Quote Share this post Link to post Share on other sites
cavscout73 0 #5 November 6, 2012 Ok maybe im missing it or just kinda retarded when it comes to cameras. but its the image stabilization im looking at right? And the 110 and 210 have the same. How do you know its ois or eos ?? Come on now its time to educate the slow guy here.. Quote Share this post Link to post Share on other sites
dragon2 2 #6 November 6, 2012 Did you read the sticky FAQ in this forum? Do that first, then go look up what kind of image stabilisation both cameras have. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
cavscout73 0 #7 November 6, 2012 by the specs both use Electronic (Steady Shot with Active Mode) image stabilization. Now with that being said, can someone look into the differences and give some feedback on the 210. From everything i can see it looks like just a newer version of the 110. But as i said before i dont know crap about the electronics behind it all. Cx 210 specs http://shop.retrevo.com/m/search/productpage?c=1004&og=1998138&m=24059177&rt=s cx 110 specs http://shop.retrevo.com/m/s/Sony-HDR-CX110-Camcorders-review-manual/id/23628ci053/t/1-2/?c=1004&og=504722&m=23628053&rt=sp Quote Share this post Link to post Share on other sites
dragon2 2 #8 November 6, 2012 LOL I could've sworn I read Optical stabilisation for the CX210. Since it's sony CX series camera, with EIS, it should be fine for skydiving. 2 other things to look out for are the ability to screw on a wide angle lens, and the location of the cardreader on the camera body, in relation to how you're going to mount the camera. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
gearless_chris 1 #9 November 6, 2012 You should also check with Trunk to see if the Hypeye will work with it. The CX160 requires a special version of Hypeye."If it wasn't easy stupid people couldn't do it", Duane. My momma said I could be anything I wanted when I grew up, so I became an a$$hole. Quote Share this post Link to post Share on other sites
cavscout73 0 #10 November 7, 2012 After some more research from hypoxic CX130, CX160, CX190, CX200, CX210, ... If the camera was made in 2011 or 2012 you will need this version of the HYPEYE! unable to use wide angle lens without some modification. http://www.gethypoxic.com/reviews-tests-hacks/hacks-and-mods/90-cx200.html Quote Share this post Link to post Share on other sites
