faulknerwn
Fisheye lenses in Florida
I travel to Florida every February to play CRW and photograph it. Florida is notoriously more humid than in TX.
My Canon 10-22 has no issues with fogging ( though it does have a simple UV filter on it). I want to be able to take fisheye photos though because they look so frigging cool. Last year I used my Canon with a 8mm lens - the common one thatis sold everywhere. Took beautiful photos other than the spot of fog dead center. Nothing worked to clear it. Thought I just had a lens with some moisture in it.
Wanted to play with my Nikon D7000 this year so I took both it and my T4i to Florida. Had the same brand of Fisheye lens on my Nikon - same problem. My Tokina 11-16 lens had no problem without even a filter.
I think because the fisheye lenses are so round that the humidity in Florida is making the dot on the lens. It doesn't do it in TX.
So my goal before I got back to Florida next year is figure out to successfully take fisheye photos!!!!
Does anyone successfully use this kind of lens in Florida? I really like the look I can get when I get my brightly colored canopy curved around the canopy formation in front of me. I'd love the look even more if I could get it without a dot of fog dead center..
I borrowed a friends Fisheye opteka lens for my cx for some jumps - it got the same dot of fog in the center while my regular video camera wide angle didnt.
It's hard for me to test this stuff in Texas because it very rarely gets so humid here..
Any ideas of how I can fix this before next year?
i have a sock filled with silica gel that I keep in my camera bag, it has served me very well in tropical climes. Also try to not have your camera in extremes of temp, i.e. cold AC'd room then walk out into the humid day.
My Life ROCKS!
How's yours doing?
This is a crazy idea, but I wonder if you could apply some sort of heater to the lens body.
You need to keep the glass element above the dew point right?
I don't know if there is enough conduction between the parts of the lens but I am picturing some heat tape around the body of the lens and a extra battery pack.
Crazy or unworkable, probably. It was just something that popped into my head!
"The restraining order says you're only allowed to touch me in freefall"
=P
Part of the issue with Fish eye lenses is the glass is much thicker than traditional lenses and this leads to the glass not warming as fast as the air around it as we descend from higher altitudes. In lower humidity environments the lens is able to stay above the dewpoint and it does not accumulate any moisture or fogging. In high humidity environments with large temperature changes it makes it much more likely for the fogging to occur. The thick glass of the fisheye will just hold the colder temperatures longer than the thinner glass of other lenses so it can fog for longer.
You can either keep the glass as warm as possible so that it does not suffer the thermal changes that would raise the probability of it fogging or try to wipe the fog from the lens to keep it from building up.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
Agreed. If you are taking your lenes from the A/C to the plane, you are asking for fogging under canopy. I can't recall a time, however, that I have experienced this with my Canon 15 2.8 in all of my jumping in Florida.
"The eyes must learn to listen before they learn to see".
randyswallows.com
It's something we've basically just dealt with while doing videos and pictures.
Generally I don't have much issue with it, but I assembled my gear when it was hot and dry, then gaffer taped the crap out of it where the lens attaches to the camera.
That helps a bit, but still get a small spot some days. If it's really humid, it might be worse, but I don't think it was that bad when you were down here.
"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly
DPH -7, TDS 578, Muff 5153, SCR 14890
I'm an asshole, and I approve this message
