jeiber
Water balloon / skyball
Ok, maybe this has been discussed before, maybe it's just a dumb idea, but I have to ask...
Has anyone tried using a (small) water balloon as a skyball? Just curious what the fall rate would be... maybe for belly flying, or not heavy enough even for that?
Maybe put some led shot in the belloon, with the water? Just brainstorming ideas here! :D
Jeff
Shhh... you hear that sound? That's the sound of nobody caring!
i'm gettin sick of flyers without the proper skills (600 falls???) not worrying about possibly killin people on the ground, ruining a dz and a pilots career...:(
I used to know an engineer at RWS who was constantly dreaming, brainstorming, and coming up with kick ass new ideas. I'd hate for him to have read a post from someone like you.
Who are you to tell someone to stiffel their creativity and imagination? He never said this plan would be put into action.
I bet most of the safety innovations in this sport have come from brainsotrming creatively with people of all experience levels.
Experience is relative. There is someone out there who makes your jump numbers look miniscule.
Tunnel Pink Mafia Delegate
www.TunnelPinkMafia.com
I'm gettin sick of negative people, with much less than all the facts, making unfounded assumptions.
Jeff
Water balloons can be lethal if travelling at high speeds, IMO.
Your right, it certainly can. I think anything hitting a person at ~160mph is going to definitely hurt, at the least. My point isn't to invent something 'idiot proof', but just something safer than throwing a lead filled ball out of a plane.
Some more food for thought: a paintball gun fires a small, hard paintball at 170-200mph, without being lethal. A larger object, that losses it's mass (and therefore energy) faster (on impact) than a paintball, should be far less dangerous.
I just hope we don't see a rash of water balloon postings in the incident reports after this weekend. :S
Jeff
Your right, it certainly can. I think anything hitting a person at ~160mph is going to definitely hurt, at the least. My point isn't to make something 'idiot proof', but just something safer than throwing a lead filled ball out of a plane.
Now... to get the water balloon to maintain it's shape and stability during freefall... Hmmm.
Jeff
It would need to be about 10" in diameter to get the necessary speed, and with a thicker skin than a regular balloon to maintain its shape.
I sure wouldn't like to be hit by one going 160mph. Kinda like being hit by a watermelon going 160mph.
Jeff
How does the kinetic energy of a paintball with a mass of a few grams, going 200mph, compare with the KE of a 15 pound water balloon going 160mph? And how does it lose its mass? Assuming it bursts on impact, the water is still going the same speed...
Edited to add - a company (UDT) in Virginia is marketing a liquid projectile anti-personnel weapon that fires much smaller "rounds" than would be needed here, at 200mph.
Your "ball" would have kinetic energy of over 12,000 ft.pounds!
10" ? How did you calculate that...I mean, are you absolutely sure?
It is probably better that it does not maintain its shape. Like a water drop, just add a tiny pull-up-cord tail, would be better to conform to the wind and add to the velocity.
...;therefore, it would be less forgiving than a watermelon. Yes, a watermelon would hurt. But a lethal waterballoon...just hard to imagine. It may explode well before any type of detrimental impact....maybe i said.
Exactly.
Where did you get the number 15 lbs? Did you make that up or is that determined by the weight of water at the speculated 10" diameter above?
It doesn't compare. It would burst into billion molecules upon contact with a fixed object. Hence, losing its combined mass.
Are you actually going to just assume that it is going to burst on impact. Dear Sir, it most definitely will.
Will it hurt? ...probably. End somebody's life? ...yet to be determined but much less likely than a spaceball.
Hmmmm. 10" isn't practical... need to figure out how to increase mass, without increasing size and fluid viscosity.
Yes, already thought of the thicker skin - at least on the 'nose'. Wax perhaps? I dunno...
Please... you can't compare being hit with a water balloon to being hit with a watermellon. :S
1) I never said anything about a 15lbs of anything.
2) I think you'll agree that water is far better at reducing kinetic energy, than say... lead?
3) A water balloon loses it's mass by exploding, and the energy is transferred to the water, which explodes in various directions.
Come on Kallend, we could use your help here! Let's mix some common sense with the science, and we might come up with something! ;)
How did you arrive at the 15lbs and 10" diameter water balloon? A gallon of water is ~8.3lbs. Ethanol (not practical here) weighs a little over 6lbs per gallon. What weighs more, but isn't toxic/explosive/etc.?
ps- looks like Vertifly and I were thinking the same thing at the same time! :D ya beat me to the 'post' button!
Physics is wonderful. Everyone should learn physics.
10" is the size you need for the gravitational force to equal the drag at 160mph on a spherical glob of water. That glob will weigh around 15 pounds. To maintain a spherical shape you'd need a thick skin, or it would flatten out and drag would increase, slowing it down.
The KE all has to dissipate somehow, regardless of how it "explodes". That energy will transfer into the object it hits.
Water is "hard" at high speed. Ever done a belly flop into a swimming pool?
A .30-30 hunting bullet has 1902 ft. lbs of energy.
Holy smokes! That means water balloons have over 6 times the kinetic energy of a lead bullet, fired from a hunting rifle! :D
Again, let's use a little common sense.... [:/]
You do realize that you're arguing with a professor of physics, right? ;)
I asked Kallend to take a look at this thread because I didn't want anyone testing this theory out this weekend on a whim. It's great that you guys have questions though, I think we're all learning something here. :)
She is Da Man, and you better not mess with Da Man,
because she will lay some keepdown on you faster than, well, really fast. ~Billvon
Anyone ever toy with one of those 3-person water balloon slingshots?
Being hit by one (which I would assume was traveling waaay slower than freefall speeds), really, really sucked.
I'd be willing to bet that even a small water balloon falling at terminal could easily kill someone.
Again, let's use a little common sense.... [Unsure]
Ok, common sense when applied to physics problems is worse than useless. What you think 'should' happen and what really does happen are very different things.
Do you want to have an ideagasm?
And he has some doubt as to whether a water balloon will break when dropped from an airplane?! :D:P
I'm up for a little science experiement here:
Vertifly and I will drop a 5lb water balloon on our heads, from a two story house.
Kallend and Jakee can drop a 5lb brick on to their heads from a two story house.
I'm confident enough in my theory....Vertifly? ;)
Jeff
