SkydiveNFlorida
mini cricket reserve ?
What makes it ok to load a pd reserve above 1:1, but not some other reserves (ie, the cricket).
PD reserves are reinforced - someone else can explain exactly where and how. Other newer reserve designs are also reinforced (Tempo, Smart, Raven Max).
Older reserve designs, like the Cricket, are not reinforced. If you load one over about 1.0 you risk having it "blow up" on you should you have a terminal or faster reserve deployment (think being head down and having your reserve deploy - it's happened).
The best guide for how heavily you can load a particular reserve is the manufacturer's maximum suspended weight.
And only newer Tempos are reenforced. Anything older then a 2001 Tempo is not reenforced.
My biggest complaint with the Minicricket (I've got 3 jumps on a Wildfire that was setup as a main) was that the entire product line just has never been updated. They designed the things in the mid 90's and walked away from them. They work, and they are tested but they never went back to improve them or anything.
Plus the toggle range was mushy.
Yesterday is history
And tomorrow is a mystery
Parachutemanuals.com
Just remember that a reserve is your last chance. PD reserves have the best reputation out of all of them. In my humble opinion, if you're trying to cut costs, try and find another way to save money (like on options on a container) and go for the PD. I've had 2 cutaways so far, and was very glad that I had my PD reserve in my bag.
She is Da Man, and you better not mess with Da Man,
because she will lay some keepdown on you faster than, well, really fast. ~Billvon
would you buy a used reserve with 0 jumps if it was not even 200$ less than a new pd reserve?
Depends on how old it is. If it's 10 years old then I'd expect it a bigger difference in price from new. If it's only a few years old then $200 less than new is a reasonable price.
Whether to go ahead and get a new one depends on how much money you have available to spend on a reserve.
ok, cool. At least now I know:)
I am not sure how much i'll have to spend. I mean, I could put a couple hundred more out for the reserve if it meant it'd be worth more when I sell it, and that it might be safer. And, well, not sure if saving 150+$ makes it worth the effort of having it shipped for inspection, etc.
thx !
Angela.
Just out of curiousity, tho. Are PD reserves just built that well compared to the rest? Are there any that do compare? What makes it ok to load a pd reserve above 1:1, but not some other reserves (ie, the cricket).
thx again:)
Angela.
PD reserves are better because they were the first of a new generation of reserves that are the first designed to be loaded more than one pound per square foot (1:1).
Other manufacturers followed suit with similar reinforced reserves with updated airfoils, materials, line trim, etc. : Aerodyne, (Smart), Free Flight (Amigo), Parachutes de France (Techno), PISA (last year of Tempo production, Precision (R-Max), etc.
The simplest way to identify modern reserves is to check for span-wise reinforcing tapes on the bottom skin.
