QuoteVertically, you have to contend with gravity of this big, fat chunk of dirt. If there was a wind blowing you, or some sort of vortex sucking you, upwards with more force than gravity (ie, wind tunnel), then yes, your fall rate would be affected. However, this really doesn't occur naturally while skydiving.QuoteDoes this mean that, as far as fall rate goes (vertically, as measured by a ProTrack), the strength of the uppers and their direction relative to the direction you are tracking, is irrelevant?
Horizontally, the wind has no other force against it... there's no gravity to fight. So when these particles in the air push you at any speed, your body has no resistance.
This is why you can push your buddy on a jump and send them across the sky horizontally, but if you try to push them up, they'll barely budge (asuming their body position stays the same).
I'm still not clear on this, sorry ;-\
Take two people with exact body types, tracking positions etc (i.e. all factors are equal) but have one track into the uppers and one track "away from" the uppers, which are at some high value.
If they both pull at the same altitude, you're saying that both will end up pulling at the same time? i.e. the duration of their flight is not affected by their orientation w.r.t the winds aloft?
That seems counter intuitive to me because the person with the uppers "behind them" will be able to go faster and hence create more "lift" and stay in the air longer. (I know that lift is the wrong term here, but hey).
Thanks,
- Andrew
billvon 3,173
Correct.
From the perspective of their wings, they both see exactly the same airspeed. Happens with airplanes too. Their _groundspeeds_ can be very different, but their wings care only about relative wind.
Correct.
Thanks, I understand now :-)
ManBird 0
Yeah. What billvon said.
"¯"`-._.-¯) ManBird (¯-._.-´"¯"
Click
Click
Click
