skydonkey
Taking up BM with shoulder injury?
I'm hoping to go BM next year. I talked to an Instructor at my DZ about it and he mentioned that he is having a lot of agro with his shoulder due to a rotator cup injury. He says that the arm position during flight is awkward as you have to push down with your arms rotated such that the backs of your hands are to earth.
I also have a similar injury from ten years ago which has started giving me some trouble recently (getting old / crappy cold British climate). Is there anything that I can concentrate on when starting out which will help? I am pretty athletic but struggle with some excercises that work the shoulder in this direction.
My Instructor also talked about the Matter suit and thinks that this requires the more natural arm position i.e. Palms to earth.??
You can fly a BirdMan suit palms to earth, as well. On the Skyflyer and Skyflyer 3, it helps to rotate your arm for the deflectors to work better, but makes no real difference on the GTi or Classic. Flying palm to earth is exactly what I recommend to those with healed up shoulder injuries. Those with current shoulder injuries should not fly a wingsuit until they've recovered.
"¯"`-._.-¯) ManBird (¯-._.-´"¯"
Click
The Matter suit requires you to pretty much fly palm to earth if you want to fly the wing correctly. On the Birdman suits in general you can fly them with palms down or with your palms bent back toward your body, much like when you grab your wing tips. CLICK ME
As far as your injury goes, you will have to play with your arm position to find which way works for you. If you have a hard time in general holding your arms out to the sides you might have to build up your Birdman specific muscle strength in that shoulder. It should not be an issue unless you have a very bad or recent shoulder injury. A few people I have taken up have had shoulder problems as well and they didn't find it overly hard on their shoulder(s) Again, your injury may or may not be compatabile. The only way to know is to try it.
SKYMONKEY PUBLISHING
