Cool, I get you drift and I agree, but its going to be really tuff to be stealthy with the noise of two mini-jets sizzling up both sides of the valley.
kallend 2,106
QuoteCool, I get you drift and I agree, but its going to be really tuff to be stealthy with the noise of two mini-jets sizzling up both sides of the valley.
Actually the small turbines aren't especially noisy. Maybe a bit more noise than a propane torch.
They sure have a prodigious fuel consumption though, because they have a very low thermal efficiency.
The small jets I have seen on RC aircraft were VERY loud.
kallend 2,106
QuoteThe small jets I have seen on RC aircraft were VERY loud.
Everything is relative, of course.
I'd rather be 6 feet from a model turbine than 6 feet from a R/C pylon racer.
piisfish 140
QuoteQuoteCool, I get you drift and I agree, but its going to be really tuff to be stealthy with the noise of two mini-jets sizzling up both sides of the valley.
I agree with you on the consumption, but sorry I don't agree with you on the noise level... These turbine are turning at around 130'000 rpm and are VERY noisy...
scissors beat paper, paper beat rock, rock beat wingsuit - KarlM
piisfish 140
As to jumping this thing off a Cliff and flying back up to the same launch spot, I think that is very unlikely. The jet engines took 30 seconds to "stabilize" before full power could be added.
Chuck
but they can be started on the ground before launching...
and edited for Kallend : concerning the piston engines, they might be more efficient, but think about : prop size and wing surface...
Are you sure you could launch such flying object from INSIDE a small plane ???
mccordia 74
Even though a lot of these project sound verry exciting, when I saw felix baumbarter with that wing on his back, and the idea of adding engines and so on I just can't help but wonder..
Why not just put a harnas under a C182 and strap 'a plane on your back'
At what point is the limit in terms of 'having something on your back' and 'hanging from it'?
With wingsuits, the human body still makes up most of the airframe, but a lot of those rigid (be it inflatable) wings have more in common with airplanes then they do with 'human (body)flight'
JC
FlyLikeBrick
I'm an Athlete?
FlyLikeBrick
I'm an Athlete?
The111 1
I like your train of thought, and while a back-mounted jet wing would not be legitimate human "body flight" in my opinion either, it might still be fun in its own regard. Probably as close as you'll ever get to being superman. It sounds interesting to me, but it's definitely distinctively different from flying a plane (which I do not have much interest in) and hang-gliding (which I do have some interest in).
www.WingsuitPhotos.com
QuoteAt what point is the limit in terms of 'having something on your back' and 'hanging from it'?
IMO, I'd say if you can walk on your 2 legs with it on your back, your not hanging from it.
The other would be it having it's own supporting system or landing gear.
www.WestCoastWingsuits.com
www.PrecisionSkydiving.com
Actually, I think of this kind of thing as being right in keeping with the spirit of BASE. Have a look at Nick's "Be Franklin" post.
"...in real terms the essence of BASE jumping is leaving behind the common wisdom, to seek out new ideas and to push the bounds of what's acceptable. "
Tom@SnakeRiverBASE.com
SnakeRiverBASE.com
