Weeeee 0 #1 June 27, 2005 i finally figured out why i get spinning openings to the right (a few cutaways). The riser tab cover on my rig opens eaiser on the left than the right. With a mix of being light (55 kg) and a smallish canopy (107), the force from the pc at linestretch is not enough to pop both riser tabs at once. Perhaps another thing to check if you get some wild openings... Quote Share this post Link to post Share on other sites
Tonto 1 #2 June 27, 2005 I'm guessing it would take more than this to spin you up. How did you figure this out? tIt's the year of the Pig. Quote Share this post Link to post Share on other sites
Weeeee 0 #3 June 27, 2005 Hi, the plastic insert, in the left tab cover, has bent with age (4 years) slightly. With the angle that lines deploy, especially with w/s jumps, there is not enough force to pop both tabs equally. I would deploy on heading, and look up to see an already turning main, line twists high up. It would always turn right. (coz the left tab released first) By tucking in the tab under the riser, i get perfect, on heading openings. Not sure if i will replace the tabs or secure them some other way... Quote Share this post Link to post Share on other sites
Tonto 1 #4 June 27, 2005 What container are you using? tIt's the year of the Pig. Quote Share this post Link to post Share on other sites
