worldsocold 0 #1 September 7, 2006 just got V2 having trouble reaching pc handle. is this normal? it's my first BIG suit. been flying an ACRO for all my other jumps. SO maybe i just need to get used to the bigger wings? but....... if anybody has any advice please feel free to school me. please. thanks.NPS SUX ASS Quote Share this post Link to post Share on other sites
bodypilot1 0 #2 September 7, 2006 Quote if anybody has any advice please feel free to school me. please. Don't go in.... Edwww.WestCoastWingsuits.com www.PrecisionSkydiving.com Quote Share this post Link to post Share on other sites
blair700 0 #3 September 7, 2006 If you are using your PC from your BOC, then you'll likely have to switch over to the leg pouch. If you are already using the leg pouch, then I can't help you as I only have a V1 and no troubles reaching the PC from the leg pouch on it. Its just differentLater Blair Quote Share this post Link to post Share on other sites
worldsocold 0 #4 September 7, 2006 i was told i could use it from my BOC. and i would like to. i'm going through the online manual now and i'm trying to figure out the leg pouchthing??? anyway any advice on the use of the BOC method or the pouch deal would be cool. thanks.NPS SUX ASS Quote Share this post Link to post Share on other sites
Professor 0 #5 September 7, 2006 Quotejust got V2 having trouble reaching pc handle. is this normal? it's my first BIG suit. It's an adjustment, you'll get used to it. Make sure you reach around the wing instead of through it. Start with your hands in the middle of the BOC and slide outward. Start your pull sequence higher until you get used to it. The wing on the V2 really wants to stay inflated due to the shoulder inlets, but I pull from the BOC every time and have had no trouble. Ted Like a giddy school girl. Quote Share this post Link to post Share on other sites
worldsocold 0 #6 September 7, 2006 good advice. it's just alot of wing to get used to. but what you said makes good sense. around not through i've only put it on once. i'll play with it tomorrow when i get time. i just want to be mentaly ready with it before i do it for real. thanksNPS SUX ASS Quote Share this post Link to post Share on other sites
notsane 0 #7 September 7, 2006 It's often a little difficult at first when you switch up to a larger wing. Like the other folks said; start your pull higher, don't rush the pull ... let the wings and grippers get out of the way for you, touch your fingers together on the bottom of your container and drag them across to grab the handle. A little practice and it'll all be second nature. Oh, and don't go in. Quote Share this post Link to post Share on other sites
LukeH 0 #8 September 7, 2006 Quote i was told i could use it from my BOC. and i would like to. you can and people have already explained how. however the leg pouch is much nicer. i guess you'd like to because it's what you know. leg pouch is the way to go.... Quote Share this post Link to post Share on other sites
phoenixlpr 0 #9 September 7, 2006 Check other thread about BASE leg pouch! That has good and bad points too. Quote Share this post Link to post Share on other sites
dragon2 2 #10 September 7, 2006 Quote however the leg pouch is much nicer. i guess you'd like to because it's what you know. leg pouch is the way to go.... Sure.... http://www.skydivingmovies.com/ver2/pafiledb.php?action=guestpass&id=fxh0n http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=2410285;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;;page=unread#unread ciel bleu, Saskia Quote Share this post Link to post Share on other sites
LouDiamond 1 #11 September 7, 2006 Start by putting the suit on when your not on a call or in a rush and just practice reaching around the wing while on the ground. Once you have a feel for it, go ahead and jump. After you make your first left/right turn off of the line of flight, go ahead and do a few practice pulls to see what shutting the suit down feels like and to touch your hack. If you find you're not getting a clean grasp on your hack, remember you can always grab your ass and slide your hands up until they hit the bottom of the container and then move them outward until you find the hack. Have fun "It's just skydiving..additional drama is not required" Some people dream about flying, I live my dream SKYMONKEY PUBLISHING Quote Share this post Link to post Share on other sites
worldsocold 0 #12 September 7, 2006 thanks i appreciate everything. when i get back from work ill try to put some of your advice to work. and try the thing on. also can somebody explain the set up on the leg pouch and the shrival flap thing. it is a little weird to me. also i've read that the leg pouch isnt alll that good for aerials especially back flying right. i like back flying sooo....... laterNPS SUX ASS Quote Share this post Link to post Share on other sites
plankton 0 #13 September 7, 2006 Quotejust got V2 having trouble reaching pc handle. I have 10 jumps with V1. I had the same problem as you first two jumps then I started use leg pouch and so no more problems at pull time at all. Pulls with base pouch is very easy. Quote Share this post Link to post Share on other sites
tr027 0 #14 September 7, 2006 Quote it is a little weird to me. also i've read that the leg pouch isnt alll that good for aerials especially back flying right. i like back flying sooo....... sooo... you do know that the V2 isn't designed or intended for backflying nor aerials, right?? I'm sure you may get away with it but you'll have to learn to use the BOC."The evil of the world is made possible by nothing but the sanction you give it. " -John Galt from Atlas Shrugged, 1957 Quote Share this post Link to post Share on other sites
hecy68 0 #15 September 8, 2006 There is a similar thred in the base zone... Quote Share this post Link to post Share on other sites
smiler 0 #16 September 8, 2006 My first two V1 jumps I used leg pouch and really wasn't happy finding it in freefall - could never find it first time, only after fumbling. I did multiple sets of 2 practice pulls, and each time I only got it cleanly on the 2nd try. But I could easily find the corner of my container where it WOULD be if I'd packed it BOC. 3rd jump onwards I packed it BOC and been fine since then, done about 100 on V1 now. Just my preference.www.wingin-it.co.uk Wingin' It wingsuit school Quote Share this post Link to post Share on other sites
