I have seen that suit in the sky a ton of times. It's called the Mach1.
chuck
New sponsor......?
![:) :)](/uploads/emoticons/smile.png)
Positively not. I pay for wingsuits these days and I do not own a Tony/Jeff suit, at least not yet. I am actually quite the thorn in Tony's side.
![:ph34r: :ph34r:](/uploads/emoticons/ph34r.png)
![:P :P](/uploads/emoticons/tongue.png)
Chuck
normiss 805
I just think you're slow....not that he's fast...
yoinks!!!
yoinks!!!
Buried 0
he's pretty good with that walker tho
Where is my fizzy-lifting drink?
QuoteI just think you're slow....not that he's fast...
yoinks!!!
I thinks that is what the texans wrote also......... Heh,... just giving you a hard time Chucky.
![B| B|](/uploads/emoticons/cool.png)
leroydb 0
OMG.... this should prove to be fun... Chuck are you on geritol now?
what about fukidtol?
Leroy
..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio...
Buried 0
QuoteOMG.... this should prove to be fun... Chuck are you on geritol now?
why do you think he moved down to FL in the first place? (you know, other than to get away from you raeford people). He was moving there to retire and grow old
![;) ;)](/uploads/emoticons/wink.png)
normiss 805
Hell we Floridians think this is a law in most states...they MAKE you move here!
Don't they???
Don't they???
![:S :S](/uploads/emoticons/wacko.png)
KrisFlyZ 0
Theoretically, if you use the 45 degree exit technique (the most efficient one) on WS BASE jump, the bigger the better because the distance you cover in the first 5-6s is directly proportional to the effective surface area (this is because at 45 degree AoA, the actual geometry of flying body has little effect on the lift coefficient).
For example, if you can clear a 200ft-wide ledge in Prodigy, and Vampire's effective surface area is (for example) double of Prodigy's, you'll outfly a 400ft ledge in Vampire over the same height.
Put Prodigy, Phantom, and Vampire on top of each other. Phantom is actually not so much larger than Prodigy, while Vampire is significantly larger than Phantom. So while Phantom gives you the convenience of BOC in BASE, Vampire is the way to go, since it starts flying faster...
Android+Wear/iOS/Windows apps:
L/D Vario, Smart Altimeter, Rockdrop Pro, Wingsuit FAP
iOS only: L/D Magic
Windows only: WS Studio
iOS only: L/D Magic
