packing_jarrett 0 #1 June 6, 2007 I'll try my best to explain myself. I have an S1 and have gotten into backflying. Has anyone tried to add back inlets to their suits via a rigger. It seems easy. Hot knife a whole into the back of the wing. sew a semi stiff seal (like sail material) over the existing inlet. Sew at the leading edge so air can still blow it open. And do the same thing but on the back side too. Here's my crappy drawingNa' Cho' Cheese Quote Share this post Link to post Share on other sites
Costyn 1 #2 June 6, 2007 How big do you plan to make the inlets? Don't forget you will have ribs to deal with, which could make it a lot more complicated; if you cut into them, repairing them might be very tricky because they're precisely shaped and stuff. Cheers, Costyn.Costyn van Dongen - http://www.flylikebrick.com/ - World Wide Wingsuit News Quote Share this post Link to post Share on other sites
VectorBoy 0 #3 June 6, 2007 Robi made Jari an S-3 with back vents that had airlocks on them years ago. It was a lot of construction complexity without "great" backflying capability. And with added losses in the belly flight mode. Since the S1 doesn't have any extra glide to spare I would get a newer platform with more wing area to experiment with. Just an Idea but if you are hell bent on tinkering stick another leg wing cell in that puppy first. Then try a PF style tetering upper vent that could be "sewn on top" of the shoulder instead of inside the suit requiring an airlock. Its my personal belief that the rear vent sewn across the mean chord amplifies the early separation of airflow which makes this type of suit not perform as well when right side up as suits that have clean wings. BTW some suits fly great backside without the vents. The S3s and S6 easily inflates due to those full profile mylar ribs that so annoying most of the time supporting the material. Quote Share this post Link to post Share on other sites
mccordia 74 #4 June 6, 2007 You could also try just adding an airlock to the front inlet. The prototype Blades we flew in spain had different legwings, that had no backvent, but an airlocked inlet on the front. They stayd perfectly inflated on the back for a whole jump, even though they didnt have an actual intake on the back. The smaller legwing on the S1 does make it a bit easyer to learn to backfly then an S3 (or any other bigger suit), due to the smaller legwing, that doesnt overpower the armwings, when you are not flying those optimal yet (when you just start backflying), so its less prone to dive headdown..JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
bodypilot1 0 #5 June 6, 2007 Quote It was a lot of construction complexity without "great" backflying capability. You sure it wasn't pilot error? Quote The S3s and S6 easily inflates due to those full profile mylar ribs that so annoying most of the time supporting the material. The hard ribs do hold the shape of the wings better, but there is no pressure inflation at all on the suits. The Blade on the other hand does have fantastic wing inflation when backflying. Be safe Edwww.WestCoastWingsuits.com www.PrecisionSkydiving.com Quote Share this post Link to post Share on other sites
Waldschrat 0 #6 June 6, 2007 Quote Quote The hard ribs do hold the shape of the wings better, but there is no pressure inflation at all on the suits. The Blade on the other hand does have fantastic wing inflation when backflying. Be safe Ed From where is the air inflating, if you are flying on your back? edit: Did you guys think my V1 could be equippet with backvents? Quote Share this post Link to post Share on other sites mccordia 74 #7 June 6, 2007 QuoteFrom where is the air inflating, if you are flying on your back? In non-vented suits with ribs, its the tension on the wing, and the ribs inside that help form the profile. So no actual inflating of the wing is at work there.. Its the mylar material pushing the wing in the correct shape. QuoteDid you guys think my V1 could be equippet with backvents? Dont see why not..JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites Tony-tonysuits 0 #8 June 6, 2007 all of our wingsuits now have backfly vents on the arms and the legs, the leg wings have the same inlet back and front and inflates way better then the old mesh inlets. pix coming soonLife is a series of wonderful opportunities, brilliantly disguised as impossible situations. tonysuits.com Quote Share this post Link to post Share on other sites bodypilot1 0 #9 June 6, 2007 Quote all of our wingsuits now have backfly vents on the arms and the legs, the leg wings have the same inlet back and front and inflates way better then the old mesh inlets. pix coming soon I didn't think this thread was intended for suit sales and promotion? Be safe Edwww.WestCoastWingsuits.com www.PrecisionSkydiving.com Quote Share this post Link to post Share on other sites Waldschrat 0 #10 June 6, 2007 QuoteQuoteFrom where is the air inflating, if you are flying on your back? In non-vented suits with ribs, its the tension on the wing, and the ribs inside that help form the profile. So no actual inflating of the wing is at work there.. Its the mylar material pushing the wing in the correct shape. Yes, i understand, the only realy ribs value ;) ....but is the Blade backvented? Quote Share this post Link to post Share on other sites mccordia 74 #11 June 6, 2007 QuoteYes, i understand, the only realy ribs value ;) ....but is the Blade backvented? The blade is airlocked/backvented yes..JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites VectorBoy 0 #12 June 6, 2007 Quote Quote It was a lot of construction complexity without "great" backflying capability. You sure it wasn't pilot error? Be safe Ed Let me correct that statement= without "great" backflight inflation. I'm possitive all lack of capability was due to pilot. Quote Share this post Link to post Share on other sites Gadget 0 #13 June 6, 2007 He holm, find me in Cochstedt and find out.Maybe i'm even let you fly it HansIf people from Poland are called Poles, why aren't people from Holland called Holes??? My logbook Quote Share this post Link to post Share on other sites aarthus 0 #14 June 6, 2007 Airlocked, backvented, backflying inlets, mylar material, and bla, bla, Bla.... it's not the suit, it's just the pilot ! Just learn to fly it .....! What else ?Patrick de Guillebon Quote Share this post Link to post Share on other sites mccordia 74 #15 June 6, 2007 Its the pilot to a large extent...but having someone backflying in a large backvented suit like a Mach1, blade etc. along with someone trying to do the same in a classic, and he's going to have a hard time keeping up.. There are people who can easely keep up with everything on their backs in 'old' suits. Way before backvents etc. where even an option. But flying a suit also designed for backflying is definately something that makes it 200% easyer..JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites aarthus 0 #16 June 6, 2007 True, it can make it easyer... but having a hard time keeping up ! best way to learn ? Best way to maximize your flight ? Depends what you are looking for ! Patrick de Guillebon Quote Share this post Link to post Share on other sites KrisFlyZ 0 #17 June 6, 2007 Quote How big do you plan to make the inlets? Don't forget you will have ribs to deal with, which could make it a lot more complicated; if you cut into them, repairing them might be very tricky because they're precisely shaped and stuff. precisely shaped ?? Why do you say that? IMO, most wingsuit wings are just approximations. To the original poster, go for it. If it does not come off as expected you would have learnt a lot in the process. The back inlet can either be contained between two ribs or be two seperate inlets. Good Luck, Kris. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
