kumhang 0 #1 September 1, 2009 I interest fly S3 with Cobalt-105. In the past I use FX-89 with my wingsuit then it's OK. Somebody who ever use Cobalt with your wingsuit. Please give me any comment. Thank you. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #2 September 1, 2009 I got a couple jumps with my Cobalt 135. My WL was 1.6+, it opened with some closed end cells. I've got it relined recently with Vectran 750. I opens harder than before. I got 2 jumps since than. I pulled that it was a small pull 1..2..3..4..5..WHAMMMM. I choose to open from full flight, I think I make less turbulence than slowing the suit down. I have opened from full flight. My Triathlon with Dacron lines opens lot softer. Oh, I jump a Stealth these days. Quote Share this post Link to post Share on other sites
likestojump 3 #3 September 1, 2009 I did about 100 jumps with a Cobalt loaded at 1.4 with an S3 I just had to make sure to keep my shoulders were level. Had a few line twists and one cutaway. it's doable, but I enjoy my Spectre a lot more :) I also had harder openings after the reline. Quote Share this post Link to post Share on other sites
JohanW 0 #4 September 1, 2009 QuotePlease give me any comment.Good luck. Do you have access to cheap or free repacks? Seeing how you profile says you normally jump an FX 79 (at a whopping 500 jumps - but not in the mood to be canopy Nazi today), I suspect you have a more or less reasonable wingload on a 105. Would be interested in knowing your exit weight though. And would like to see some video of landings (the average ones, not the perfect ones). Personally, I prefer my Triathlon for wingsuiting. But if an FX-89 worked for you, no reason why a Cobalt-105 would not work. Did you downsize the FX and is the -79 not working?Johan. I am. I think. Quote Share this post Link to post Share on other sites
VectorBoy 0 #5 September 1, 2009 I've got hundreds of cobalt/wingsuit jumps @1.4 with no problems. 1 cut away on a ws/cobalt @1.6. The last 200 wingsuit jumps have been on a tri @1.4 but I will admit the cobalt is way more fun. Obviously wing loading is very important and how much of a "big suit" you have. Quote Share this post Link to post Share on other sites
kumhang 0 #6 September 2, 2009 I just downsizing to 79 about 12-13 jumps. Not sure with my S3. Thanks Quote Share this post Link to post Share on other sites
kumhang 0 #7 September 2, 2009 my wingloads with cobalt-105 about 1.6 , Thank you for every comment. Blueskies Quote Share this post Link to post Share on other sites
Martini 0 #8 September 2, 2009 2 choppers on Cobalt 120 @ 1.6, didn't like the canopy much anyway so I sold it. I prefer a higher w/l on the Cobalt, unfortunately that doesn't make it more wingsuit-friendly.Sometimes you eat the bear.............. Quote Share this post Link to post Share on other sites
leroydb 0 #9 September 6, 2009 i had same setup... probably 100+ jumps on it,..... only issues was one jump with line twists that I couldnt get untwisted...Leroy ..I knew I was an unwanted baby when I saw my bath toys were a toaster and a radio... Quote Share this post Link to post Share on other sites
kumhang 0 #10 September 9, 2009 How about your wingload ? Thanks Quote Share this post Link to post Share on other sites
JanuszPS 0 #11 October 6, 2009 Another question: Cobalt 150 @ WL 1.25 - would that be acceptable and recommended by experienced wingsuit jumpers? I made 6 jumps so far on that canopy and Phantom 2 and experienced one line twist but only soft and super soft openings. Comparing to my Sabre 2 150 the openings were softer and statistically not worst in terms of line twists or better. I might have some issue with body position so that can be the main reason for line twists on Sabre which happen quite frequently (1/4 jumps). I also made couple of jumps on Cobalt 120 @ 1.6 and WS but one opening was quite hard and 180 deg so I decided not to jump with it. Any ideas? Regards JanuszBack to Poland... back home. Quote Share this post Link to post Share on other sites
phoenixlpr 0 #12 October 7, 2009 You can jump whatever you want if you are comfortable with it.I jump Triathlon 160 or Cobalt 135 with wing suit. I'm still more relaxed with Triathlon. Its more fun to jump cobalt, because my has some closed end cells on opening.... Quote Share this post Link to post Share on other sites
phoenixlpr 0 #13 November 3, 2009 I got 30 jump on my Cobalt with wing suit. In 10 jumps in 2 days I just got use to it. As someone else said you can jump wing suit with whatever canopy if you are comfortable with its openings. QuoteAndrew Ryan: We all make choices in life, but in the end our choices make us. Quote Share this post Link to post Share on other sites
Ludde 0 #14 November 3, 2009 I've made about 100 wingsuit jumps with a Cobalt (or Impulse) 105 at 1.6 with only a couple of linetwists in the end. Probably because of bad line trim. No cutaways. It's probably a really bad idea to start jumping wingsuit with such canopy though.It's not over untill the bearded lady swings! Quote Share this post Link to post Share on other sites
phoenixlpr 0 #15 November 3, 2009 QuoteI've made about 100 wingsuit jumps with a Cobalt (or Impulse) 105 at 1.6 with only a couple of linetwists in the end. Probably because of bad line trim. No cutaways. I got it relined with Vectran before started to jump actively with wing suit. Quote Share this post Link to post Share on other sites
