gus
Containers for mismatched canopies
Is the Wings EXT the only container that will let you have mismatched main/reserve canopies, ie a Cobalt 65 and a PDR 281? (exagerated example)
I found some old posts talking about mismatched canopies causing problems if you have 2 out, is that why more manufacturers aren't making it an option?
Gus
OutpatientsOnline.com
Any container manufacturer will custom make a rig to virtually any combination of main and reserve sizing.
not quite. I just e-mailed RWS about getting a vector3 with a larger reserve than main, and they won't. I believe you can't get a javelin or rigging innovations container with a size difference either, but you would need to check with them to be sure.
________________________________________________________
Abbie drove me to Idaho and all I got was this lousy sigline
Say what? Is this the same RWS that built my Vector 3M 357 to fit
a Samurai 170 with a PD218R? They had no problem with that.
"There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones.
I basically got the same response. It's a shame becasue I quite fancy a 'hotter' main but the more I think about it the less I want to downsize my reserve and I really fancied a Vector3.
Gus
Also try asking the guys who build Infinity (Velocity in Kapowsin) or Sidewinder (Flying High in Alberta).
The basic problem with mis-matched canopies is that you have to design a new rig, a process that can take anywhere from a few hours to a few weeks. On really complex rigs - i.e. Micron - it takes several tries to make all the flaps fit together perfectly. All this design work requires time and money. It is hard to justify a week's work to draw a pattern that you will only ever build one of.
I know because I used to test-pack all of Sandy Reid's prototypes at Rigging Innovations. Most of them were close, but still needed "a 1/2 inch here and shift this bartack a 1/4 left, etc.
