sky-pimp 0 #1 September 11, 2011 Its that simple , where can i get a copy of the manual to this wingsuit? ive looked on the net and on the birdman site but not found anythingYeHaaaaaaaaaaa Quote Share this post Link to post Share on other sites
Zeemax 0 #2 September 11, 2011 What info are you looking for? How to lace the suit up? Have you had an FFC yet? That should be covered as part of the course. As should flying it. If you need any help, depending on where you are in the country, give me a shout and i'll talk you through it Phoenix Fly - High performance wingsuits for skydiving and BASE Performance Designs - Simply brilliant canopies Quote Share this post Link to post Share on other sites
Titanium_Gecko 0 #3 September 11, 2011 Macca, The issue is how the cutaway handles are stowed on the suit. The handle has a stiffened tuck tab and slot/pocket on the suit body and it was MY query about tucking the tab in from the top or the bottom. Hence, my suggestion to Sky-Pimp to see if there was a manual out there somewhere. When tucked in from the top, you then need to do an upward movement to free the handle before pulling down to cut-a-way the wings. When tucked in from the bottom, the handle was already starting to slip out whilst moving around on the ground and the cables starting to also slip down. Rosswww.gathhelmets.co.uk www.flyyourbody.com Quote Share this post Link to post Share on other sites
Titanium_Gecko 0 #4 September 11, 2011 Sky-Pimp, See below, Lou Diamond maybe able to help http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=3784317&mh=25&t=search_enginewww.gathhelmets.co.uk www.flyyourbody.com Quote Share this post Link to post Share on other sites
mccordia 74 #5 September 11, 2011 Those type of handles always seemed to loosen/slip on blades/firebirds. Though stifner etc helps a bit, best is a simple velcro patch to stow it properly, so it doesnt unexpectedly pop out. If the bootie doesnt have the simple snap, but the fabric 'get in the way' bit, also replace it. You dont want an open legwing mid front/back transition, or during a barrelroll. These 2 problems whete sadly never adressed during the final (pre-jeans) days of birdman, even though many people (including members of the 'factory team') mentioned/asked...JC FlyLikeBrick I'm an Athlete? Quote Share this post Link to post Share on other sites
Zeemax 0 #6 September 11, 2011 It tucks in from the top. As Jarno mentioned though, that system was never great. A rigger should be able to make a simple velcro mod to make it stay put better.Phoenix Fly - High performance wingsuits for skydiving and BASE Performance Designs - Simply brilliant canopies Quote Share this post Link to post Share on other sites
Titanium_Gecko 0 #7 September 12, 2011 Sky-Pimp, Found this for you.... http://www.fly4fun.com.ar/archivos/Birdman.pdf Cheers, Rosswww.gathhelmets.co.uk www.flyyourbody.com Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #8 September 21, 2011 QuoteIt tucks in from the top. As Jarno mentioned though, that system was never great. A rigger should be able to make a simple velcro mod to make it stay put better. What they said. I always added another piece of plastic stiffner to the backs of all of those handles to keep them in that slot, but adding a bit velcro is a big help, even then. Quote Share this post Link to post Share on other sites
